  1. Hi, I'm planning on buying the Ati All In Wonder video card the specs say that you can capture at 30 frames per second. My ? is that a good speed for video capture. I was trying to avoid buying a firewire card and go with the video card instead.
    Armand
    Jan 2004
    Baton Rouge, LA
    Yes, 30 fps is the norm. Actually it's 29.97, but they rounded it. Once you start getting into video capture, you find out all kind of neat things.
  3. Member BrainStorm69's Avatar
    Aug 2002
    Texas, USA
    Armand
    AS mentioned by briandugas, 29.97 if you are from someplace that uses the NTSC standard. 25 FPS if you are from someplace that uses PAL.
