    Nov 2002
    Italy
    Hi,
    I have converted an audio wav file of a movie in order to multiplex it with TMPGE.
    I have used BeSweet, the profile DSPguru MP2 for SVCD. When I came to multiplex, TMPGE says that the file is an illegal MPEG format.
    I also tried using the Default profile in Be Sweet but same result.
    Why ?
    I converted instead the same wav file using TMPGE into MPEG-1-Audio Layer II and it works fine.
    Thank you
  2. TmpgEnc's multiplexor is spotty at best when using audio files created with other programs. I use ][muxer for my multiplexing and have never had a problem.
