Does any one have a Tutorial (that works) that will convert avi-dvd,
Now there is a way that you can make 3 avi's fit on a DVD obnce they are converted, i know you have to edit the VOB files
but i cant finad any info any where
can you help?
I agree with the above process. You didn't say the total running time of your avi's. Assuming they're about 90 min each that's 4 1/2 hrs on a DVD. The average video bitrate will need to be about 2000 kbps and the audio 224 kbps to allow that much time. I suggest 1/2 DVD resolution (352x480/576) and 2-pass VBR with a 500 minimum and 8000 maximum.
Here's a bitrate calculator.
BTW, editting of VOB's isn't required, you author all three clips at the same time.
"Art is making something out of nothing and selling it." - Frank Zappa -
thx guys,
but i dont wanna convert to Mpeg unless its Mpeg 4 which is DVD
is that possible? -
DVD video is usually mpeg2 but can also be mpeg1. Read up "what is DVDR" over there <-<-<-.Originally Posted by Seymore
Here's a basic guide.
Mpeg4 is usually found in avi type files."Art is making something out of nothing and selling it." - Frank Zappa -
If you want to play on a stand alone DVD player you will have to convert the AVI. What I suggest if you want to fit multiple films on one DVD-R is to convert to VCD using TMPGenc . Then use TMPGenc DVD Author which will convert the audio to DVD compliant 48K, you can fit 7.5 hours of Video on a DVD-r using this method.
DVD's are normally MPeg2 but I sometimes use MPeg1 to fit more than one film on a DVD-r and find the quality to be very good.
help me how to make a set of avi files to DVD with menus of each avi file
By mmah in forum Video ConversionReplies: 5Last Post: 9th Mar 2011, 03:07 -
Found DVD/AVI software player that displays Chinese srt subtitles with avi
By jimdagys in forum Software PlayingReplies: 1Last Post: 14th Nov 2009, 20:45 -
Making sure AVI is compatible with DVD players
By uniks in forum Newbie / General discussionsReplies: 1Last Post: 25th Jul 2009, 18:31 -
Will joining two AVI files cause problems later in making DVD by Nero 6?
By wayney in forum EditingReplies: 1Last Post: 17th Jun 2007, 21:18
