I have successfully burned a VCD with still images. The VCD works fine on my PC using PowerDVD, however it won't run on my home DVD player, which does not seem to recognise the format, although it is supposed to read VCDs, SVCDs, and support PBC.
- I have tried VCD and SVCD formats
- I have tried both high and low resolution images
- My home DVD player seems to work fine with VCDs produced by other commercial packages (Photo2VCD pro)
Any ideas on how to set up VCDEasy so that it works with my DVD player (Thomson DTH 5000 x) ? My primary need is to have a solution for reviewing digital photos on my TV using my VD player.
Help would be greatly appreciated !
It sounds like you are having the same problems that I am having. See my post "Help! Interavtivity does not work". I also know that my player has PBC because I have been successful also with commericial authoring software. Did you ever find out what the problem was?Originally Posted by yves.martelle
thephoto vcd has been made without the pbc function.. i have a jvc standalone dvd player. if i hold my finger on the stop button i have 2 choices s(vcd) or rgb . if i choose s(vcd) pbc mode comes in the display and the photo vcd works. look inyour standalone dvd player handbook on the pbc mode.
i hope that helps
will .vob files alone play in a home dvd player?
By vincy in forum Newbie / General discussionsReplies: 7Last Post: 4th Feb 2012, 06:04 -
Play MKV file on Home DVD Player
By ladkvayo in forum DVD & Blu-ray PlayersReplies: 7Last Post: 14th Apr 2011, 07:42 -
help finding player. USB and play from home network
By billkater in forum DVD & Blu-ray PlayersReplies: 0Last Post: 17th Dec 2010, 22:39 -
Cannot play burned dvd on home dvd player
By ellemacamelle in forum ffmpegX general discussionReplies: 11Last Post: 11th Aug 2010, 19:18 -
i got an dvd9 movie and it couldnt play on my home dvd player
By techworld in forum Newbie / General discussionsReplies: 1Last Post: 6th Oct 2007, 06:57
