Results 1 to 21 of 21
  1. Well I have to tell ya pioneer 120s owners should rejoice. This version of Shrink eliminates any problems with that Dvd rom drive.
    Believe me I know I own one and in past versions got nothing but errors. But now it works perfectly. A single layer disk was ripped in 7 min 3 sec. a double layer in 15 min 3 sec. Not bad for a one gig processor with 512 megs of ram huh? And the quality is excellent! I had bought a liteon 166 drive to replace my 120s but found the pioneer drive to work better. The 166 has what I think is a nasty habit of lessening the read speed once it hits a high rip point, that the pioneer doesnt. Now with this version of Shrink my 120s works flawlessly with all the software available. One other thing, I dont know why but this version of Shrink increased the read speed almost 3 fold, amazing. Well all I can say is Thanks!
  2. Damn I wish this happened a week ago as I just bought a Lite-On so I could use DVD Shrink. Anyone want to buy a slightly used Pioneer 120 DVDROM?
    (Before anyone jumps me for trying to sell something here, it was just a joke).
  3. Member Zetti's Avatar
    Dec 2003
    Canada
    While 3.0b5 always worked fine for me, the new version (both 3.1.5 and 3.1.6b1) crashes suddenly with an "exception error...";
    I'm trying to burn the disc image to the HD,so I think it's no DVD writer issue...I have room on both HD's;
    The source higher-than-4.7GB DVD has been authored in DVDitPE; it has many movies but I've realized the this program merges all into just one VTS....maybe it has something to do ?
    Does anyone know how to report possible bugs to Shrink Author ?
    Thanks,
    Zetti
  4. Does anyone know how to report possible bugs to Shrink Author ?
    http://forum.digital-digest.com/forumdisplay.php?s=&forumid=62
    We'll need more details though. Does it only happen with DVDitPE authored discs being an important one.
    ddlooping
    For DVD Shrink guides & goodies: DVDShrink.info
    My "other" site: Teaching-Tools
  5. Member Zetti's Avatar
    Dec 2003
    Canada
    Ddlooping,
    If you're thhe Shrink Author, congratulations for wonderful job !
    Well, it's been some weeks or so since I don't use Shrink, now that I needed it, I instaled 3.1.5 and deleted 3.0b5 - that always worked wonderfully, that's why I got surprised, I expected no problems;
    What is more interesting is that Nero Recode latest version did the job just fine, and as far as I've heard the author of both programs is the same person;
    I'll try to quickly author a BIG DVD in Maestro and make a test, yesterday I tried Shrink several times, with errors and crashes in all times;
    I'll return to this post later,
    Thanks,
    Zetti
  6. If you're thhe Shrink Author, congratulations for wonderful job !
    No I'm not, but thanks for the positive feedback.
    ddlooping
  7. Member golfnut's Avatar
    Sep 2003
    Could someone please tell me where I can download DVDShrink 3.1.6 b1, I can't find it anywhere. Thank you.
    Thank You,
    GolfNut
  8. Member golfnut's Avatar
    Sep 2003
    ddlooping, thanks so much for the quick reply.
    Thank You,
    GolfNut
  9. ddlooping,
    What's new(or fixed) in 3.1.6b2?
  10. Guys, I don't want to sound alarmist, but I would advise you not to use v3.1.6 right now, and to stick to v3.1.5 Final.
    I think I might have discovered a nasty bug, but I'll know more about it after I've had a chat with dvdshrink, as it might only be related to my particular setup.
    ddlooping
  11. More info about the bug can be found here.
    ddlooping
  12. What exactly is the Pioneer 120 bug? I just shrunk the movie An Italian Job and I can not play the movie on my Pioneer 563A standalone player. The player keeps trying to boot up the movie over and over. I thought it was the media(Optodisc) but I switched to Ritek but still doing the same exact thing with a new burn. I was using shrink3.1.5 and let it shrink directly from the DVD drive to the hard drive. Will I be able to fix the already shrunk movie from the HD with say DVD2ONE and reburn the movie? Thanks.
  13. The Pioneer 120S is a DVD-ROM.
    The "120 bug" usually happens at the layer-break when ripping.
    DVD Shrink (and CloneDVD too I think) simply stops and give an error message.
    dvdshrink - the developer - purchased a 120S to do some testing and try and fix this bug.
    Apparently he was able to do so, but I have the feeling this introduced a new bug.
    This still has to be confirmed though.
    ddlooping
  14. Oh, only during layer break? Hm, it may be a different problem. But they both are Pioneer brand. I was able to play the newly burned DVD in a DVD-ROM, which made me think it was the same problem as the DVD 120.
    Anyone encounter the same problem that I am having?
    Try it:
    1) Open Shrink while the DVD movie is in the ROM
    2) Backup directly from ROM to HD.
    I usually use DVDecrypter to to the ripping part. This was the first time I let Shrink do the ripping/backup at the same time. It had been so reliable with previous version until 3.1.5.
  15. nooner6, I also have a Pioneer set-top, the fairly old DV626D, and have only encountered problems when using v3.1.6b.
    ddlooping
  16. The Pioneer 563A is relatively new. It's one of these hybrid DVD player that plays both DVD-A & SACD. I also support WMA but I have not tried it yet. There must be something that Pioneer doing that's different than other DVD. I play the problem disc on my PC and the movie played fine. I am going to try and put the problem DVD in and let DVDecrypter rip it and run it through DVD2ONE and see if that fixes the problem, whatever the problem is
  17. I just took the problematic DVD disc to my computer and try to let DVDecrypter to rip it. DVDecrypter came back with an error message:
    Failed to patch file!
    C:\ITALIAN_JOB\VIDEO_TS\VTS_01_0.BUP
    Reason: Invalid IFO /BUP.
    Shrink 3.1.5 must've done something not right.
    Anyone knows how can I correct this? Can it be fixed or it needs to re-process?
  18. nooner6, I can only suggest try again with DVD Shrink.
    Something might have messed up your first attempt.
    ddlooping
  19. Unfortunately, I don't have the original movie with me at the moment. I let it to my sister who lives about 3 hrs away. That was my newly bought movie that I want to back up. I already wasted 2 disc and I don't think I want to let shrink do the backup directly from the DVD-ROM again.
  20. Hello again.
    v3.1.6b4 seems to have fixed the bug I was experiencing.
    I say "seems" because I had to use DVD-RW as I'd run out of DVD-R.
    I didn't believe the problem was due to media in the first place though, so I can recommend using v3.1.6b4.
    http://www.dvdshrink.info/temp/dvdshrink316b4.zip
    ddlooping
