I just puchased a LiteOn 166s DVD-ROM because so many people rave about it on this forum. Does anyone know which firmware will give me the fastest rip speeds? I'm using ConeDVD and anydvd but only ripping at about 4x,30 minutes on average for a DVD9. I have a P4 2.0 Ghz running winXP Home. I've already checked to make sure DMA was enabled. Also, I've never installed aspii drivers, are they already in windows or do I need to install them?
Drew66
Have you tried a different ripping prog? (dvd decrypter is free). Sometimes that does the trick.
Maybe the aspi layers has something to do with it but I think you'll be needing them at some point anyways. Someone else here may be able to fill you in on that.Boy do I love my avatar! -
Thanks, I got up to 8x using dvd decrypter, it must be something in CloneDVD slowing it down.
That would be about right for a dual layer disc.
Try a well pressed, commercial single layer disc and you'll notice the rip speed increasing beyond that mark as it approaches the outer rim.
liteon hbs112 firmware
By davechubb in forum Blu-ray RippingReplies: 5Last Post: 5th Feb 2012, 13:19 -
Liteon dvd recorder
By mangbok in forum DVD & Blu-ray RecordersReplies: 3Last Post: 21st Jul 2010, 14:37 -
Change to Gateway/Liteon firmware
By knights89 in forum DVD & Blu-ray RecordersReplies: 4Last Post: 26th Dec 2009, 16:32 -
Help Liteon DVD recoder
By killingme in forum DVD & Blu-ray RecordersReplies: 9Last Post: 24th Apr 2009, 18:46 -
change hd in liteon 5025
By DENAR in forum DVD & Blu-ray RecordersReplies: 4Last Post: 11th Sep 2007, 12:47
