Hi there
On DVD X Copy Platinum, I'm puzzled on where I can decide which features I want to rip.
For example, if Im copying a DVD that needs compressing, is there an option, where I can choose to, let's say, disregard the audio commentary for instance, so more quality can go into the picture and sound? And if so, where is it?
Thanx very much.
"I would be honoured to care for your fish!" - Rob Schneider, Deuce Bigalow: Male Gigolo
Why not just use DVDShrink? It's free, idiot proof and works perfectly. If you read the comments about DVD X Copy Platinum, it seems very few have anything good to say about it.
dam man richard is just trying to make your life easier. course if i paid for that shit. i would be trying to force myself to use it. so it would atleast look like it wasn't a total waste of money.
How Big A Boy Are Ya? -
AGAIN, THANX 4 THE OPINION, BUT CAN SOME PERSON WITH JUST AN OUNCE OF INTELLIGENCE ANSWER MY INITIAL QUESTION!
CAN YOU ON DVD X COPY PLATINUM, DEDUCT CERTAIN FEATURES, BEFORE YOU RIP THE DVD, SO MORE QUALITY GOES INTO THE PICTURE AND SOUND?
"I would be honoured to care for your fish!" - Rob Schneider, Deuce Bigalow: Male Gigolo -
No, I don't believe you can which is one of the reasons DVD X Copy sucks. You can however select the degree of compression for each title so that you can maximize compression on less important material.
http://www.dvd-guides.com/guides.php?category=dvdcopy&name=platinum -
Cannonball
This is very helpful. Thanx very much
Just one final question 4 u.
On STEP 5, part 2, it says that you can alter the compression gauge thing, to give the movie more quality, than the extras, well, is it the higher you set the gauge, the better the picture, or vice versa?
p.s. Also, on the same section, what does that tickbox labelled Lock Titleset mean? (Beneath the arrow named 2.)"I would be honoured to care for your fish!" - Rob Schneider, Deuce Bigalow: Male Gigolo
Bluray ripping audio options
By nry in forum AudioReplies: 0Last Post: 4th Nov 2008, 08:44 -
DVD Burning software options
By BarnabasB in forum Newbie / General discussionsReplies: 15Last Post: 9th Jun 2008, 13:50 -
DVD Menu Options
By BritGuy79 in forum Newbie / General discussionsReplies: 3Last Post: 20th Mar 2008, 16:47 -
Making a dvd clone..what are my best options please?
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 4Last Post: 29th Nov 2007, 09:51 -
tape to dvd am I using the better options
By pantsdavies in forum Authoring (DVD)Replies: 1Last Post: 6th Nov 2007, 11:32
