I have come across something unusual - hope you can help.
I have a original DVD that plays on both sides. ie, side one has half of the movie and after it finishes then it prompts you to turn the disc over to continue the movie.
My question is that both sides play fine on my dvd player downstairs. But on my powerDVD 5 on pc - it only plays side A. Hence - I can only copy half of the movie on my dvd burner. It doesnt recongnise side B - neither in DVD shrink/DVD decrypter etc. Any ideas???
Riaz
Riaz Ahmed
I assume you mean play side B? Yes - I have ... just no luck!
Riaz Ahmed -
try ripping each side with dvd decrypter in file mode first. then send it through dvdshrink, it might not need to be shrunk, bur that will insure the files are readable, then burn
Thats exactly what I mean - it doesnt read it in dvd decrypter. It doesnt read side B. Strange isnt it?
Riaz Ahmed -
I shall have a good look tomorrow and get back to you.
RiazRiaz Ahmed -
i have a sony dw-u10a every time i burn either a dvd-rw or dvd+rw
when i put it back into my pc it says no disc it cant read any of them after burning please can somebody help
Copying a DVD
By grominnetto in forum Video ConversionReplies: 5Last Post: 17th May 2010, 21:31 -
Copying Speed Slows Down as Copying Progresses
By Soopafresh in forum ComputerReplies: 3Last Post: 25th Sep 2009, 22:03 -
Copying DVD's
By lsvtec in forum DVD RippingReplies: 2Last Post: 16th May 2008, 04:06 -
Re:Copying a dvd rw
By lol23 in forum Authoring (DVD)Replies: 5Last Post: 18th Oct 2007, 06:54 -
copying my old dvd's
By mustang1967 in forum Newbie / General discussionsReplies: 1Last Post: 22nd Aug 2007, 00:43
