Is it possible? I own a lot of a DVDs, and I'd like to make backups of them. But to burn em all on DVD-Rs will be very costly, so I'm looking for a way to compress them, but STILL keeping the Surround sound, such as Dolby Digital and DTS. Maybe manage to reducd the size to 1-2gb, so 2-3 movies can fit on ONE dvd. So, in short: Can I make DivX/SVCD with 5.1 audio?
Results 1 to 12 of 12
Although I haven't made one myself, that's a pretty common file type. Usually they're 700 MB (1CD) or 2 X 700MB (2 CD).
"Art is making something out of nothing and selling it." - Frank Zappa -
I've did several Divx conversions so far with good results. The easiest way is to download trialware Dr DivX from divx.com. I think it's 30 days or so trial. All setting are adjustable but the program is designed to be easy to use. I liked it enough I bought the full version.
You can also use the free divx codec and VirtualDubMod or VirtualDubMpeg2 (loads M2V) but you will need to setup the codec manually. A little harder for a newbie to divx. Read a few guides, learn how to 2 pass using Job Control, and there is actually nothing to it. I do it that way sometimes also.
Getting that AC-3 audio muxed is easy with a little program called AVIMux GUI. Just run the program, drag in your divx video and your AC-3 audio from Windows Explorer. Click the video stream, click 'add', then click Run. Easy and fast multiplex. The program has some errors thought and you will find it necessary to sometimes load that muxed file in VirtualDub, setup for Direct Stream Copy (audio and video), and save a new avi. This will repair the problems giving you a good file.
Oh yea, when you rip the dvd demux the vob files with Tmpgenc Mpeg Tools to get your AC-3 audio out. Don't process it, just mux it back to your finished divx converted avi like I said above. Demux the video stream (m2v) and take that to VirtualDubMod or Dr Divx for processing.
And I almost forgot. For VirtualDub to handle AC-3 audio you will need to install AC-3 ACM Decompressor (as mentioned above). lol
Good luck. -
or use autogk or fairuse 0.3, both can convert to divx or xvid with ac3 audio.
Guys,
I apoligise upfront if I'm wrong about this but my understanding of how the AC-3 ACM Decompressor filter works is to accept a 5.1 ac3 in but downmix it to 2 channel stereo for use in re-encoding the audio to another format. So I don't understand how, just by using the decompressor you get 5.1 ac3 audio out with VirtualDub?
If the original poster wants true 5.1 ac3 then he doesn't need to re-encode the audio (unless he wants to use BeSweet to drop the bitrate) just remux it with the avi at the end.
So ,too my mind ,for the process he wants the decompressor is irrelevant (although a great tool to have). -
Originally Posted by feenix
Good luck.
EDIT: Out of curiosity I uninstalled my decompressor and tried a direct stream copy. VD did 'direct stream copy' without it, but it could not play or process the ac-3. lol -
I'm gonna try not proccesing the sound, but if you manage to get a movie to DivX size, and still keep 5.1 channels, then thats goods stuff!
I just realized that my DivX/DVD player also plays AC3, so I can guess that my DVD-writer will get little rest from now on.
Increasing Audio volume on AVI/DivX/Xvid with AC3 Audio
By Spacedementia87 in forum User guidesReplies: 21Last Post: 24th Dec 2021, 07:21 -
DivX audio Q
By Tafflad in forum Newbie / General discussionsReplies: 7Last Post: 25th Jul 2011, 12:13 -
No audio on divx file
By didikai in forum AudioReplies: 5Last Post: 30th May 2010, 09:33 -
Converting Divx w/ Vorbis audio to Divx w/ MP3
By tachyon2u in forum AudioReplies: 3Last Post: 23rd Feb 2008, 23:35 -
no audio on some divx files
By philquad in forum AudioReplies: 6Last Post: 1st Dec 2007, 23:16
