Ive recently resolved my dma/pio problems with my pioneer 106d (well temporarily) and now ive encountered another problem which may be related to the orignal problem (im not sure).
Basically when im writing a dvd movie (other formats such as audio cd work fine); my writer seems to have periods where it does nothing, then possibly 5-10 mins later it kicks in again. The dvd still writes ok but it can take up to an hour to write a dvd at 4x.
When its writing/hanging there are no problems with system resources/cpu usage so i know it hasnt reverted from dma to pio, which was my original problem.
Any clues anyone :P
Results 1 to 10 of 10
What kind and have you tried other burning software?
MMMMMMMMMMMMM..........sprinkles -
I don't mean to hark on the obvious or insult anyone, but, I take it you have already obtained latest BIOS and VIA 4.37 chipset drivers and have checked for properly installed ASPI in XP
sounds like its running in PIO mode,instead of DMA.
on my BIOS ive got a setting that lets me pick between UDMA and PIO.
has to be enabled to write and use my hard drives in DMA mode.
which is a pain..1 hour for a dvd and 45 mins to unzip some files sucks.
so what you could do is right click on my computer,select properties,then go to hardware,device manager and click on IDE devices,and see if theres a DMA setting there.
if not then see the bios,and finally,take out the 106,and reinstall it,but in device manager,uninstall if from the system.
that might solve the problem. -
already tried that, thats what i did to solve the problem of my writer using all my cpu power...it kept reverting to pio mode....which is something to do with xp detecting x ammount of errors and so it switches to PIO. I reinstall the IDE channels to solve the CPU usage problems but it doesnt fix the hanging problem.
hm,same thing for me on a 106/Firm1.07 and the older 104Originally Posted by Rud
it's only whit:
RNM4.50 latest px-engine >not all times but the nasty bug is there..
Dvd-decrypter3190 or older versions
the strange thing no probs using IMGTool1.1.0 >uses Nero 6.3.0.0 on 1x,2x,4x,a steady burn each time and no probs on the dvdplayers
but the post by "Redman66" makes make go check out my aspi etc..
system:
XP Pro corp+SP1 all updates
PIII - 800Mhz
BIOSTAR V6931 >its old,never updated the BIOS so that's same from "2000"
but why fix if things aint broke? cuse al the rest is running good
nways to keep it short,your not alone but its weird yeah,gets ya tripping aint it?!
havent a clue what that meansOriginally Posted by -=Phaze-=
btw. ive used ASPICHK.exe and it says ive got no aspi installed...should i? -
sorry bro for bad english
anyways what i mean:
I got same problem using:
RecordnowMAX 4.50(latest px-engine installed) and
Dvd-decrypter(any version)
it doesn't do that whit IMGTool though!
my aspi is installed correct i guess
screenshot:
A Pioneer DVD fix it problem
By kenmt in forum DVD & Blu-ray RecordersReplies: 6Last Post: 23rd Jul 2010, 09:03 -
Showbiz DVD2 vs 2.2.15.106 vhs capture problem
By zulubase in forum Capturing and VCRReplies: 0Last Post: 13th Feb 2010, 19:28 -
Pioneer DVR 533HS Problem
By Hollywood_Mike in forum DVD & Blu-ray RecordersReplies: 25Last Post: 13th Aug 2008, 12:35 -
Region problem with Pioneer
By bltprf in forum DVD & Blu-ray WritersReplies: 10Last Post: 28th Jan 2008, 05:36 -
Pioneer DVR 533 Problem -
By chris_james in forum DVD & Blu-ray RecordersReplies: 4Last Post: 17th Aug 2007, 02:59
