I have a picky slvd300p sony dvd player. Memorex and tdk dvd-r disks don't work very good, they skip. I have some BeAll that work good most of the time. I bought some dvd-wr by Imatation mainly for data and they seem to burn the best for my player. I thought that dvd-wr was less compatible on stand alone players. These disks are too expensive for everyday use. Wonder if I should try Imitation dvd-rs. What are your thoughts?![]()
He who goes to bed with itchy butt wakes up with a stinky finger.
Imation doesn't make their own discs. They are made by various other manufacturers, and they aren't always the same brand. First you should try and find out who really made the -RW discs you are using (use DVD Indentifer, etc. to read the info on the disc).
Samsung BD-P3600 DVD+R compatibility
By ynoldus in forum DVD & Blu-ray PlayersReplies: 5Last Post: 14th Oct 2009, 14:55 -
DVD burner compatibility with Dell
By LWC in forum ComputerReplies: 14Last Post: 29th Nov 2008, 08:17 -
Check for DVD-compatibility
By otternase in forum Video ConversionReplies: 1Last Post: 29th Aug 2008, 03:58 -
dvd player with the best compatibility?
By JCWagener in forum DVD & Blu-ray PlayersReplies: 23Last Post: 16th Nov 2007, 21:17 -
Increasing DVD playback compatibility
By Truelight54 in forum Authoring (DVD)Replies: 1Last Post: 15th Oct 2007, 17:51
