I have a DivX movie that is 640 x 272 with 25fps, converted it to an mpeg of the same resolution, and tried to burn it as a VCD with Nero. Nero complained about it not being compatible for a VCD, but i went ahead and burned it any way. When i played it in my DVD player, there was no picture, just a garbled mess. How can i burn a compatible VCD and still have it be 640 x 272???
VCD is 352x240 (NTSC) or 352x288 (PAL) - if you want to have a VCD Nero will like it has to be in that resolution. You could try to convert to SVCD - 480x480 NTSC, 480x576 PAL.
See the CONVERT section for more help.
<font size=-1>[ This Message was edited by: kitty on 2001-10-21 11:47:07 ]</font> -
Your DivX 640x272 seems to be a 1:2,35 widescreen movie without borders.
To make it SVCD compliant and playable on a 4:3 TV, you have to resize, for example with Avisynth.
AviSource("C:\.......\.....avi")
BicubicResize(480,320)
AddBorders(0,128,0,128)
<font size=-1>[ This Message was edited by: Truman on 2001-10-21 13:01:22 ]</font>
Burning SVCD At 480 x 272, 1152 kbps ?
By Tham in forum Authoring (VCD/SVCD)Replies: 2Last Post: 16th Sep 2010, 15:21 -
how to record with 640*352 format
By Haboob1st in forum DVB / IPTVReplies: 5Last Post: 3rd Jun 2010, 19:39 -
640 ac-3 for DVD
By chrchr in forum AudioReplies: 57Last Post: 12th Mar 2010, 14:16 -
Authoring a DVD with AC3 640 bitrate - can it be done?
By Slimbo69 in forum Authoring (DVD)Replies: 11Last Post: 9th May 2008, 10:11 -
Would 640 X 272 to 720 X 400 be correct?
By hydrophonicaudio in forum MacReplies: 19Last Post: 24th Jul 2007, 11:33
