Hey everyone. When I download You Got Served SVCD TS-loGisTic it is a mpeg file. my question is. since it says that it is a SVCD format in the title and it comes in an mpeg file, if i use my Video CD tool in most burning programs, will that Video CD tool convert the mpeg into just a VCD instead of a SVCD, or will it convert it to SVCD format? because i thought mpeg files were only VCD formats? any help would be great, thanks
thanks for the reply. that was some good info. my questions was if it was svcd and in mpeg file format, then can i just say like recordnow max videoCD option to just burn it on the CD? will that try to convert the mpeg file to just a VCD? not SVCD like how the mpeg was originally. or does the recording tool just covert it accordingly, to VCD or SVCD depending on the file? or does it always try to convert an mpeg file to VCD?
No, you need to burn it as SVCD.
If you read the info at that link you would see that SVCD uses a different file structure and different mpeg settings from VCD.
It will see the mpeg as NOT VCD compliant and will probably try to convert it (assuming recordnow max can do this, I have never used this particular program).then can i just say like recordnow max videoCD option to just burn it on the CD? will that try to convert the mpeg file to just a VCD?
Free software to split large MPEG-PS file into many small MPEG-PS files?
By videonewbie22 in forum Newbie / General discussionsReplies: 9Last Post: 5th Jul 2018, 19:16 -
Choppy playback of some MPEG-2 files and all IFO files
By ANOther1676 in forum Software PlayingReplies: 2Last Post: 8th May 2011, 06:04 -
Convert .mpeg-files to .vob-files?
By stuckinsnow in forum Authoring (DVD)Replies: 1Last Post: 21st Sep 2008, 04:06 -
No audio in powerdvd for mpeg 1 and mpeg 2 files
By Bully9 in forum AudioReplies: 2Last Post: 2nd Jan 2008, 07:23 -
DATA files rather than MPEG files from a DVD-Video?
By DieselsDen in forum Newbie / General discussionsReplies: 11Last Post: 14th Dec 2007, 03:24
