I have a pc with win XP Home sp1 on a 80Gb HD. I need to format the HD and then reinstall win XP. I just want one partition. Can anyone tell me how to do that? Thanks.
You can prepare the new partition using your XP install CD - be aware though that once you do this, all data on that disk is lost - but I'm sure you know this.
If the disk is already a single 80gb partition then you don't need to re-partition, during the XP installation you will get the option to re-format the partition as part of the install process.
If you want to re-partition/format first then do the following:
1. Boot to the XP CD.
2. When it gets to the screen that asks whether you want to install or repair, select Repair.
3. Select the OS and then at the Command Prompt C:\> type 'DiskPart' and press enter.
4. You will see the existing partitions - you can highlight each partition and press D to delete (then L to confirm).
5. When you have deleted all partitions you will see a single entry that says 'Unpartitioned Space' - hightlight this and press 'C' to create a single partition over the whole disk (accept the default sizes) and press enter.
6. You should now have an entry that says "Partition 1 [New (Raw)], you may also have a little bit of Unpartitioned space left over - just ignore this.
7. The new partition is un-formatted at this stage but you can leave it this way because when you install Windows you will get an option to format the partition, however if you want to format at this stage see below.
8. Now press ESC to get out of the Disk Partition option and get back to the Command Line prompt.
9. If you want to format at this point then type "format c: /FS:NTFS" or "format c: /FS:FAT32" depending on the type of file system you want.
10. When finished type "EXIT" which will re-boot the PC. Again boot to the CD and this time select the Install XP option.
FORMAT FACTORY 2.70 Installation Error
By gonwk in forum Newbie / General discussionsReplies: 1Last Post: 6th Jul 2011, 20:59 -
Can I install Win Vista HP with installation CD
By pchan in forum ComputerReplies: 21Last Post: 9th May 2011, 09:37 -
"FLV splitter" installation in Win 7(64)?
By Blå_Mocka in forum Newbie / General discussionsReplies: 3Last Post: 6th Dec 2010, 14:22 -
Sharp Mini DV firewire not detected by Win 7 but was working under Win XP.
By thintin in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 6th Jun 2010, 02:12 -
Win 7 and XP dual boot issues. Can't access one of the drives in Win 7?
By Denvers Dawgs in forum ComputerReplies: 3Last Post: 13th Jun 2009, 22:51
