Here is my problem:
I am trying to copy a DVD-R for a friend. At first I tried DVD shrink, but that gave me the error of "Invalid file structure". Then I tried DVD Decrypter, and it gave me an error too. I've even tried to copy/paste the files over, but Windows gives me "Unable to copy files" . The DVD-R is the only copy I have.
Anyone have any other suggestions?
I think you will find the original poster has worked that out for him / herself, hence trying to copy it across in Windows.
I suggest ISObuster, or reading the disc in your writer. If the worst comes to the worst, roll back to your original, assuming it's not protected under copyright in which case what you're doing is a no-no. -
If the DVDR was burned with errors, you can't copy it(typical with a bad burn or bad media). Windows can't copy something with errors. What you would have to do is rip it with dvddecryptor (ISO mode, ignore errors), then burn the ISO.
Try DVDInfoPro to check the disk for errors.To Be, Or, Not To Be, That, Is The Gazorgan Plan
DVDFab Blu-ray Copy vs. DVD Copy
By coody in forum Blu-ray RippingReplies: 1Last Post: 11th Oct 2010, 12:33 -
Copy of a Copy of a Protected VHS Tape to DVD
By solarblast in forum DVD & Blu-ray RecordersReplies: 12Last Post: 18th Dec 2008, 07:36 -
Is copy Sony PSP game same as copy DVD disc?
By coody in forum ComputerReplies: 10Last Post: 15th Dec 2008, 07:26 -
How can I copy a copy-protected DVD and have only ONE VOB file
By Aafour in forum DVD RippingReplies: 3Last Post: 6th Oct 2008, 00:31 -
Unable to copy copy-protected data DVD
By J_Kirk in forum ComputerReplies: 9Last Post: 22nd Jan 2008, 11:23
