I have learned that I need to buy a firewire card (with input port) and a firewire cable to connect a digital camcorder to my PC and get the best quality capture. Is this the right thing at the link below? Will this work? Decent deal? http://www.pagecomputers.com/cgi-bin/page/S0771969.html
Thanks very much!
Hi heyjjjaded,
Yep, looks like what you're after. About the right price too.
Disclaimer: I don't know the manufacturer nor the vendor, and can't guarantee that it'll work etc. blah blah you get the idea. In my opinion, it sounds right, not a recommendation.There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
Thanks, daamon -
I'm just trying to make sure that I'm not missing anything or misunderstanding something. Thank you! -
No problem.
It looks like you also get Ulead trial - Check that out in the "Tools" section to see if it's half-decent. I've never used it...
If it's an "all-in-one" (i.e. capture/edit/encode/author/write to disc) package then it'll be OK for starters but I'd recommend looking into how to do each step separately with the best tools for the job.
Good luck...There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
I think you can find the fireware card and cable cheaper; here for example:
http://www.newegg.com/app/Viewproduct.asp?DEPA=1&order=PRICE&submit=list&catalog=1&des...chFor=firewire
Make sure you determine what number of pins for your cable. Typically, camcorders have 4 pins and the fireware PCI computer card has 6 pins. As you can see from the link above 4 pin to 6 pin cables can be had for as cheap as $3.
Here is a list of the cards some as cheap as $10:
http://www.newegg.com/app/Viewproduct.asp?DEPA=1&order=PRICE&submit=list&catalog=73&de...=&srchFor=ieee
AG-DV1000P -- Firewire Connection Crapped Out??
By jbd5010 in forum Capturing and VCRReplies: 6Last Post: 6th Apr 2011, 12:34 -
Firewire Connection - how to secure??
By motown01 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 23rd Nov 2009, 14:39 -
What is the difference in connection of DV and pc between USB and FireWire?
By coody in forum Capturing and VCRReplies: 2Last Post: 11th Dec 2008, 15:17 -
firewire connection without sound
By m baqar in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 25th Apr 2008, 09:10 -
Testing Camcorder Firewire Connection
By wacole in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 13th Nov 2007, 11:41
