Hi,
I am using DVDLab to author a DVD. I have 5 clips that I want to put togeher onto one disc with menu.
4 of the clips (2 mpg and 2 VOB) are all at D1
1 clip (a VOB) is at half D1
DVDLab gives me a warning about the different resolutions, but lets me continue. It creates the DVD. When I burn it and play it, the half D1 clip is super pixelated, the rest is fine.
My question is, what is the best way to fix the problem? The half D1 clip, by itself, plays great (no pixelization) on all my drives.
I would appreciate any and all advice.
The warning that you are receiving from DVD-lab probably stems from the fact that all clips in the same video title set (VTS) are supposed to have the same properties (resolution, aspect ratio, etc.). You need an authoring tool that can add multiple title sets. The PRO version of DVD-lab allows you to add a second title set. There is a guide on how to do it at http://www.mediachance.com/dvdlab/tutorial/multivts.html . The PRO version is only in beta form now and must be installed to a registered copy of the regular version of DVD-lab. A download for the PRO version is available on Mediachance's website.
Tools used: ScenalyzerLive 4.0, Adobe Premiere Pro 2.0, Adobe After Effects 7.0 Professional, Adobe Encore DVD 2.0, IFOedit 0.96, DVD-lab PRO 1.53, Adobe Audition 2.0
Very Mixed Requirements
By juliam in forum Newbie / General discussionsReplies: 7Last Post: 4th Jul 2011, 23:15 -
Authoring a mixed-media/resolution Blu-ray?
By jbigfoot in forum Authoring (Blu-ray)Replies: 4Last Post: 20th Jun 2010, 21:37 -
Mixed Multi Angle DVD Encoding Problem
By werdna1900 in forum Video ConversionReplies: 3Last Post: 11th Jun 2009, 04:32 -
How to make a mixed DVD
By Baldrick in forum User guidesReplies: 60Last Post: 4th Sep 2008, 13:01 -
DVD LAB : Different sound in different movie (MIXED SOUND): NOT WORKING?
By SteamrollerLive in forum Authoring (DVD)Replies: 2Last Post: 24th Jun 2007, 18:01
