    Jul 2001
    I have been waiting for DVDx to include chapters but now I don't understand how to set it up in version 1.6?
    When I click on chapter info I get a list of the chapters and a button with "Dismiss" on it?
    How do the chapters work with this and is the film kept as one track with chapter points or is it cut up into separate chapters?
    I want chapters but not if these a pause between each one?
    Also in the input settings, for VCD do I need the Dolby Surround ( spelt with one "r"?) ticked or not? With surround I assume you mean Pro-Logic?
  2. There's a user guide in the downloaded zip, it has the answer to your question.
    Jul 2001
    Thanks for that, I did not see it!
    I'm still not sure what it will do what I want?
    It looks like you can rip individual chapters or groups but if I rip all the chapters as one file will the mpeg have chapter entry points when I make a VCD?
  4. I've sent the guide to you via email. Check!
    I believe if you want to create a 3-chapters VCD, you need to have 3 MPG files.
    Jul 2001
    Thanks but I did have the file its just I did not see it in the program folder until you said
    What I want is to be able to make a chapter entry point every 5 mins or where the chapters are on the DVD. I don't want the mpeg to be cut at every chapter point.
