  1. I just bought PIRATES OF THE CARIBEN, and want to make a backup of the movie DVD. But using first DVDDecrypter for copying the files files to my HD. Then I use DVDShrink 3.0 Beta5.
    It tells me that it can not recognize the files. I never had the problem with all my other DVDs.
    Anybody can tell me the reason or what I can do to avoid this?
    I am used to make copies of my DVDs, because the children most of the time don´t look after the DVDs, so having a copy of it saved a lot of money these years.
    Anything is welcome.
    Thx
    Johny
  2. I had no problem to back it up with AnyDVD 3 and Nero Recode 2
  3. No problem here doing movie-only with DVDShrink 2.3
    Pull! Bang! Darn!
    Dec 2002
    You ripped it the wrong way. Shrink doesn't read IFO rips. Either rip it raw, or as an ISO and mount it with Daemon tools.
    Why are you ripping it first anyway, Shrink 3.05 and up will rip by itself.
    To Be, Or, Not To Be, That, Is The Gazorgan Plan
  5. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    Yep....if you insist on using DVDDecrypter first....you gotta use "file" mode and SELECT ALL so DVDShrink will open it.
