Please can someone point me too, provide a link to or tell me a little more info regarding audio bitrates.
I have read other posts, guides and tried to find more info but only found tidbits.
Basically what sort of audio bitrate do the different qualities of audio use?
stereo, mono, surround sound etc?
thanks in advance
Hi zworg2,
Your questions fall into the "how long is a piece of string?" category - except that, in this case, it's also "and what is the string made of?"
In short, there's loads of formats that can have either fixed or varying bitrates, and can be mono, stereo, 6 channel etc.
It might be easier if you say why you need to know and that might help to narrow down the options of an answer...
Note: I'm no audio expert, just know enough to know that your questions don't have simple answers.
Good luck...There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
Fairy Nuff...
I am authoring DVD's from AVI 's
When i seperate this into audio and picture (in TMPGEnc) i have to set the audio bitrate.
I dont want to set it too high and waste time, but i dont want to set it too low and f*** up my soundtrack!
most of the stuff i will be working with will be simple stereo (two channel) only
What bitrate (approx) should i use to keep the quality but do it as quickly as poss.
i have been using 224..can i go lower?
thanks in advance -
If you are using AC3 compression on the audio, then I've seen acceptable audio quality as low as 192.
If it's MP2 audio, then I tend to go a little bit higher(224 or 384), although I would think that 192 there would be OK as well.
I'd do some tests and see what sounds good to you and through your stereo equipment. -
Avi to DVD can be broken down 2 ways.
1) MP3 Audio. Typically this will be Dolby surround downmix of a 5.1 stream if the source is DVD. Stereo if it's a capture or older DVD. Leave the bitrate the same (ie if the AVI as 192 kbps MP3, then convert it to a 192 kbps MP2 or AC3). It's usually 128 or 160 kbps, but can be as low as 96 or 64 kbps (nasty sounding).
2) AC3 Audio. Just leave it intact, no need to convert (unless your player hates it, then it's probably a BeSweet conversion).To Be, Or, Not To Be, That, Is The Gazorgan Plan
Need Help With Deciding on Bitrates
By W1nks in forum Video ConversionReplies: 12Last Post: 6th Dec 2011, 11:17 -
MP4 File Audio Bitrates
By SE14man in forum Newbie / General discussionsReplies: 3Last Post: 19th Sep 2010, 11:51 -
WD TV reccomended bitrates
By SCDVD in forum Newbie / General discussionsReplies: 3Last Post: 2nd Nov 2009, 00:20 -
I need some help understanding bitrates...
By pwhyles in forum Newbie / General discussionsReplies: 1Last Post: 7th Apr 2008, 14:54 -
MP3 Bitrates..
By SE14man in forum Newbie / General discussionsReplies: 1Last Post: 23rd Aug 2007, 22:50
