  1. Is it possible to create chapters on svcd same as on DVD menus ? which software can do it ?, free or not i wil buy it
  2. Hi
    I used TSCV https://www.videohelp.com/sefy/?id=chapters1.html for the purpose and it works very well. I also wanted to make the menus for my VCD. After doing al the necessary things at the MenuGen Tab of TSCV, I click on Creat Menu and after the menu's for different chapters have been created, it promts me to save the file as mpv for still menus or as mpg for motion menu's.
    Here is where I get stuck. Even after saving this file, the file does not get saved at all... and I get the error on log window as
    Starting VCDxBuild process...
    initializing libvcd 0.7.12 [cygwin/i686]
    this is the UNSTABLE development branch!
    use only if you know what you are doing
    see http://www.hvrlab.org/~hvr/vcdimager/ for more information
    front margin set smaller than recommended (0
    rear margin set smaller than recommended (0
    could not stat() file `C:\Documents and Settings\chaos\Desktop\chapterList.mpg': No such file or directory
    VCDxBuild finished
    Can you please help me figure out where I am doing wrong and what!
    Skull
