Results 1 to 9 of 9
    Aug 2001
    Could anyone tell me how to make a backup of an already made backup that i made with dvdxcopy platinum?
    I have searched the forum but no answer worked, is there anyone here who have succeded in doing this?
    Sincerely Zilwer
  2. obviously you didnt search that much, because this has been discussed over and over.
    rip in iso mode with dvd decrypter, burn with dvd decrypter (or burning program of your choice).
    hell, you should be able to copy the files off the disc and burn them to a dvdr.
  3. Or just make another backup of your original...
    Aug 2001
    Well i wont work with dvd decrypter i get error messages on every try i do
    that says
    I/O Error
    (And some other rubbish numers and stuff)
    Interpretation Unrecovered Readerror
    Anyone else get this, and how do i fix it. Does anyone use any other method?
    Sincerely Zilwer
    Mar 2003
    Uranus
    The way to fix that is burn with Verify , and do it again until
    the verify succeeds. Your burn had errors. Try reading the disk in
    the burner , if you didn't already
    Dvdxcopy is good buddies with the MPAA , It won't copy a copy.
    I don't know why people use that
    Aug 2001
    My burn dont have errors, bcs, all my copys gets the same errors, but someone out there must have a sollution to this, if it doesnt work with dvddecrypter, what should i do?
    Sincerely Zilwer
  7. Use your original "Purchased" DVD that you should have put away for safe keeping... ????????? You do have the original right... Becouse not owning the original and trying to make copies is illegal and against forum rules to ask how to do things illegally.....
  8. Member jbelder's Avatar
    Jun 2004
    Denver,Co
    Sincerely Zilwer
    I have used Nero Recode 2 and also Intervideo Dvd Copy 1.2 also works just fine.
    James B Elder
  9. Member ViRaL1's Avatar
    Jan 2004
    Making the Rounds
    If your original backup that you got from DVD X Copy (single disc) is fine, and you have no need to do anything other than duplicate it, you can use Nero disc copy or Roxio disc copy.
    Nothing can stop me now, 'cause I don't care anymore.
