When I capture in MPEG-2 through the ATI Multimedia Software, the quality is so much better than MPEG-1. But after capturing in MPEG-2, I can't open the file in any conversion tools eg TMPGenc. It can de-multiplex and then re-multiplex it again and can see the specs eg 480x480 and bitrate. TMPGenc says that the the file unsupported. Is there anyway of getting past this?
<font size=-1>[ This Message was edited by: hotmat4 on 2001-10-21 08:05:49 ]</font>
Try load the file in virtdub and save it with divx compression.
After that I think the MPGenc will admite it as a good file. -
uncle_joe did you read his post? thats not good advice at all. to convert mepg-2 to divx so you can use it in TMPGEnc is a very bad suggestion. I dont have the answer for hotmat but I wanted to make sure he knew that converting it to an AVI format is NOT the answer.
Sound with ATI AIW 9800 Pro
By andrewjameshoward in forum Capturing and VCRReplies: 1Last Post: 8th Aug 2010, 07:02 -
ATI AIW 9700 pro capture card problem
By INFRATOM in forum Capturing and VCRReplies: 8Last Post: 31st Mar 2009, 12:26 -
ATI AIW 128 720x480 mpeg captures have horizontal tearing
By cybertheque in forum Capturing and VCRReplies: 16Last Post: 17th Sep 2008, 21:53 -
Populating empty ATI VIP / AMC feature header on AIW Rage 128 Pro
By cybertheque in forum Capturing and VCRReplies: 3Last Post: 14th Sep 2008, 16:36 -
Didn't ATI All in Wonder 128 Pro have Mpeg capture?
By Ensign in forum Capturing and VCRReplies: 7Last Post: 7th Mar 2008, 10:13
