Hey Baldrick, could you code a function that will allow us to delete several private messages at once? Like you can with most Email accounts. Say for instance a check box by each message that will allow you to delete in one go instead of one at a time.
It takes me forever to delete my messages, its all TIbrO's fault, that crazy nerd loves to send me private messages:
Im sure that he would like the feature as I send him just a many, LOL. Im sure speedy would like to mass delete all my messages to him as well... I dont think he likes me much, hehe.
okey....will do it as soon as possible(a year or two....)
damn it! faster... before that crazy TIbrO "private message bombs" me again! He fills up my private message list faster than you can say "You have 99 new private messages".
If you want I will learn PHP and code the damn function for you - probably be faster that way, LOL.
I hope you mean fly years... ant years or something... for the love of God man! Its PHP - The language was designed for lazyness! Probably only take 3 lines of lame-ass-high-level-slow-running code anyway!
okey...here is the code...just add a sql delete statement and remove link.
<?php
viewpmsg.php - description
begin : Wed June 19 2000
copyright : (C) 2000 by James Atkinson
email : james@totalgeek.org
$Id: viewpmsg.php,v 1.18 2001/02/07 21:58:48 bartvb Exp $
* This program is free software; you can redistribute it and/or modify
* it under the terms of the GNU General Public License as published by
* the Free Software Foundation; either version 2 of the License, or
* (at your option) any later version.
* viewpmsg.$phpEx - Nathan Codding
* - Used for receiving private messages between users of the BB.
include('extention.inc');
include('functions.'.$phpEx);
include('config.'.$phpEx);
require('auth.'.$phpEx);
$pagetitle = "Private Messages";
$pagetype = "privmsgs";
if (!$submit && !$user_logged_in) {
include('page_header.'.$phpEx);
login_form();
} else {
if (!$user_logged_in) {
if ($user == '' || $passwd == '') {
error_die("$l_userpass $l_tryagain"
if (!check_username($user, $db)) {
error_die("$l_nouser $l_tryagain"
if (!check_user_pw($user, $passwd, $db)) {
error_die("$l_wrongpass $l_tryagain"
/* throw away user data from the cookie, use username from the form to get new data */
$userdata = get_userdata($user, $db);
if(is_banned($userdata[user_id], "username", $db))
error_die($l_banned);
// Log them in, they are authenticated!
$sessid = new_session($userdata[user_id], $REMOTE_ADDR, $sesscookietime, $db);
set_session_cookie($sessid, $sesscookietime, $sesscookiename, $cookiepath, $cookiedomain, $cookiesecure);
$sql = "SELECT * FROM priv_msgs WHERE (to_userid = $userdata[user_id]) ORDER BY msg_time";
$resultID = mysql_query($sql, $db);
if (!$resultID) {
error_die("Error getting messages from DB."
<TABLE BORDER="0" CELLPADDING="1" CELLPADDING="0" ALIGN="CENTER" VALIGN="TOP" WIDTH="95%"><TR><TD BGCOLOR="<?php echo $table_bgcolor?>">
<TABLE BORDER="0" CELLPADDING="3" CELLPADDING="1" WIDTH="100%">
<TR BGCOLOR="<?php echo $color1?>" ALIGN="LEFT">
<TD WIDTH=20% COLSPAN=2><?php echo $l_from?></TD>
</TR>
<?php
if (!mysql_num_rows($resultID)) {
echo "<TD BGCOLOR=\"$color1\" colspan = 2 ALIGN=CENTER>$l_nopmsgs</TD></TR>\n";
while ($myrow = mysql_fetch_array($resultID)) {
echo "<TR BGCOLOR=\"#F1EDED\" ALIGN=\"LEFT\">\n";
$posterdata = get_userdata_from_id($myrow[from_userid], $db);
echo "<TD width=15% nowrap valign=top><font face=Verdana Size=2>$posterdata[username]
\n";
$posts = $posterdata[user_posts];
echo "<a href=\"bb_profile.$phpEx?mode=view&user=$posterdat a[user_id]\"><img src=\"$profile_image\" border=0 alt=\"$l_profileof $myrow[poster_name]\"></a>\n";
if($posterdata["user_viewemail"] != 0)
echo "<a href=\"mailto
posterdata[user_email]\"><IMG SRC=\"$email_image\" BORDER=0 ALT=\"$l_emial $posterdata[username]\"></a>\n";
//if($posterdata["user_web"] != '') {
// if(strstr("http://", $posterdata["user_web"]))
// $posterdata["user_web"] = "http://" . $posterdata["user_web"];
// echo "<a href=\"$posterdata[user_web]\" TARGET=\"_blank\"><IMG SRC=\"$www_image\" BORDER=0 ALT=\"$l_viewsite $posterdata[username]\"></a>\n";
// if($posterdata["user_icq"] != '')
// echo "<a href=\"http://wwp.mirabilis.com/$posterdata[user_icq]\" TARGET=\"_blank\"><IMG SRC=\"http://wwp.icq.com/scripts/online.dll?icq=$posterdata[user_icq]&img=5\" BORDER=0\"></a>";
/*if($posts < 15)
echo "<font size=-2>$rank1
\n";
else
echo "<font size=-2>$rank2
\n";
echo "
<font size=-2>$l_posts: $posts
\n";
echo "$l_location: $posterdata[user_from]
</FONT></TD>\n";*/
echo "</FONT></TD>\n<TD width=85%><img src=\"$posticon\"><font size=-1>$l_posted: $myrow[msg_time] ";
echo "<HR size=1 color=white></font><font face=Verdana Size=2>\n";
$message = stripslashes($myrow[msg_text]);
echo $message . "
echo "<HR size=1 color=black>\n";
//if($posterdata["user_aim"] != '')
// echo "<a href=\"aim:goim?screenname=$posterdata[user_aim]&message=Hi+$posterdata[user_aim].+Are+you+there?\"><img src=\"$aim_image\" border=\"0\"></a>";
echo "<a href=\"replypmsg.$phpEx?msgid=$myrow[msg_id]"e=1\">$l_replyquote</a>\n";
echo "<a href=\"replypmsg.$phpEx?msgid=$myrow[msg_id]\">$l_reply</a>\n";
echo "<a href=\"$url_phpbb/delpmsg.$phpEx?msgid=$myrow[msg_id]\">$l_delete</a>\n";
echo "</TD></TR>";
} //while ($myrow = mysql_fetch_array($resultID));
$sql = "UPDATE priv_msgs SET msg_status='1' WHERE (to_userid = $userdata[user_id])";
if (!mysql_query($sql, $db)) {
error_die("Error marking the messages as read in the DB."
</TABLE></TD></TR></TABLE>
<TABLE ALIGN="CENTER" BORDER="0" WIDTH="95%">
<TR>
<TD>
</TD>
<TD ALIGN="RIGHT">
<?php make_jumpbox()?>
</TD>
</TR></TABLE>
<?php
} // if/else
require('page_tail.'.$phpEx);
here do you add the delete sql statement...
<?php
delpmsg.php - description
$Id: delpmsg.php,v 1.8 2001/02/07 20:44:21 bartvb Exp $
* delpmsg.php - Nathan Codding
* - Used for deleting private messages by users of the BB.
login_form();
} else {
error_die($l_userpass);
error_die("$l_wrongpass"
$sql = "SELECT to_userid FROM priv_msgs WHERE (msg_id = $msgid)";
$resultID = mysql_query($sql);
if (!$resultID) {
echo mysql_error() . "
\n";
error_die("Error during DB query (checking msg ownership)"
$row = mysql_fetch_array($resultID);
if ($userdata[user_id] != $row[to_userid]) {
error_die("That's not your message. You can't delete it."
$deleteSQL = "DELETE FROM priv_msgs WHERE (msg_id = $msgid)";
$success = mysql_query($deleteSQL);
if (!$success) {
error_die("Error deleting from DB."
echo "
<TABLE BORDER=\"0\" CELLPADDING=\"1\" CELLSPACING=\"0\" ALIGN=\"CENTER\" VALIGN=\"TOP\" WIDTH=\"$tablewidth\">";
echo "<TR><TD BGCOLOR=\"$table_bgcolor\"><TABLE BORDER=\"0\" CALLPADDING=\"1\" CELLSPACING=\"1\" WIDTH=\"100%\">";
echo "<TR BGCOLOR=\"$color1\" ALIGN=\"LEFT\"><TD><font face=\"Verdana\" size=\"$FontSize2\">
echo "
<center>$l_deletesucces $l_click <a href=\"$url_phpbb/viewpmsg.$phpEx\">$l_here</a> $l_toreturn
</center></font>";
echo "</TD></TR></TABLE></TD></TR></TABLE>
} // if/else (if submit)
cool... can you post the code all the other functions this site uses? Especially the user authenticating functions and the user database.
... and your user database? LOL!
Im not coding your functions dude... I'm an "313373" C programmer, wouldnt want to dirty my hands with PHP now would I? ROTFLMAO.
here:
#include <stdio.h>
#include <string.h>
void main()
char coder[]="baldrick";
char name[10];
char name1[]="Lamer";
char name2[]="313373";
puts("What is your name?");
gets(name);
fprintf(stdout,"%s is a %s\n",coder,name1);
fprintf(stdout,"d4n13l is '%s'\n",name2);
fprintf(stdout,"LOL\n\n");
if(!strcmp(coder,name))
fprintf(stdout,"Get coding lazy bones...
\n\n\n");
fprintf(stderr,"...like now dude!");
else
fprintf(stdout,"you are 1337 - do not dirty your\n");
fprintf(stdout,"hands with a\n");
fprintf(stdout,"high-level lamer language
fprintf(stdout,"\n
\n");
/* coded by d4n13l... not cut 'n' pasted from "hotscripts" hehe */
put that in your compiler and smoke it!
LOL
<font size=-1>[ This Message was edited by: d4n13l on 2001-10-22 16:09:11 ]</font>
Account deletion?
By tgp1994@gmail.com in forum Newbie / General discussionsReplies: 3Last Post: 3rd Apr 2011, 01:21 -
Feedback: vbulletin, private messages
By vhelp in forum FeedbackReplies: 8Last Post: 28th Feb 2010, 12:05 -
Baldrick has exceeded their stored private messages quota
By lordsmurf in forum FeedbackReplies: 0Last Post: 27th Jan 2010, 22:30 -
Account Deletion
By Deluge in forum Off topicReplies: 7Last Post: 9th Oct 2008, 22:35
