I have a stand alone Philips DVDr80 +R recorder. Since stand alone recorders use a different writing strategy than a DVD burner I should be able to use 2.4x, 4x, 8x media with out any problems correct? The firmware has been updated to FF16d which is the latest.
I have heard that the 4x media has a little different quality controls than the 2x and you might get a little better recording out at the edge of the discs?
I don't have a DVD burner only a DVD player. Is there any program I can use the check the mfg. code are should I be concerned since I use a stand alone recorder?
klsparrow
Results 1 to 1 of 1
ffmpeg to windows media server - what does the code look like?
By cyberskoglund in forum Video Streaming DownloadingReplies: 0Last Post: 1st Oct 2010, 14:50 -
Trouble playing ripped DVD with Windows Media Center 2005-bad country code
By nzdreamer55 in forum DVD RippingReplies: 3Last Post: 6th Mar 2010, 10:28 -
Phillips DVD+R, 16x, media code: CMC MAG. M01...These any good?
By i am x in forum Newbie / General discussionsReplies: 1Last Post: 15th Mar 2008, 10:26 -
Same media code, wildly different reviews
By richapple in forum MediaReplies: 5Last Post: 1st Feb 2008, 00:25 -
Fry's GQ dvd-r16x media code ISSM is horrible
By strpyw in forum MediaReplies: 4Last Post: 19th May 2007, 09:57
