Hello
I have a dual pentium processor dell workstation with windows 2000 Professional installed. I am having problems burning dvds with Nero.
I also have a Pinnacle DC2000 capture board installed
DVDs burn fine when used with Pinnacle DVD Impression Pro
Sometimes Nero works--sometimes Nero does not. When nero never indicates a failure--the discs just don't play to the end and the burn looks blurry. This happens with all media used.
Does anyone know of a burning software that will work with dual processors?
Thank you
Results 1 to 10 of 10
That is strange. What version of nero?
I run Hyperthreading with nero 6.3.0.3 without any problems. As far as I know, nero cannot tell the difference between a true dual processor and a hyperthreading system.
If a program is not dual processor compatible, it will just utilize one processor. So any program should work. -
I did run a different version of nero with lots of problems though. Buffer underruns, DVD didn't play, stuttering, but that was all fixed with an upgrade to the current version.
So your problem might be a crappy version of nero, and not the fact that you computer is a dual processor. -
Hello
Thank you for the reply.
The version of nero is 5.5.9.16--this came bundled with my pioneer dvdr 105.
I will look into the newer nero--I will be on the lookout for a sale.
Thanks again. -
Thanks for the information indolikaa
I'm gettint too bleary eyed for a download tonight from nero and this will save me from having to purchase a new version. -
You don't need to buy anything. Just go here and download the latest version of Nero 5. It is version 5.5.10.54:
http://www.nero.com/us/631933457317970.html -
Originally Posted by indolikaa
The Nero knockers should use this.Regards,
Rob -
Thanks to all
I upgraded my Nero through the link supplied by Falberni and I also upgraded the firmware on my Cendyne rebadged Pioneer dvr 105 from 1.0 to 1.33. Recording is now stable/
Once again my thanks to all who responded.
What do you use for a software word processor?
By johns0 in forum PollsReplies: 12Last Post: 22nd Feb 2012, 04:36 -
Intel Slashes Quad-core, Dual-core Processor Prices
By louv68 in forum Latest Video NewsReplies: 0Last Post: 22nd Apr 2008, 18:14 -
I'm Building a NEW computer - core2duo or dual xeon processors ???
By tug_hill2 in forum ComputerReplies: 5Last Post: 7th Mar 2008, 23:12 -
Dual Core vs Dual Processor
By kissvid in forum ComputerReplies: 59Last Post: 17th Jun 2007, 10:27
