I have a Nintaus DVD player in my livingroom.
The DVD player plays DVD/VCD/SVCD/MP3/+++ + + +
Nice DVD player with a PAL TV.
How can I burn my MPG's and MPEG's that resides on my PC, and take the cdr to my Nintaus DVD player in my livingroom and play them there ??
I have tried the burnmpg page here, without success
Anyone ?
Thanx!
Sanwa
First, you have to consider a lot of things like:
1. Is your DVD player compatible with CD-R or CD-RW? Try to be sure about it.
2. What speed recording are you using? Try 2X, it maybe slow but it gives good result. What burning software?
3. Are you burning your MPEG files in the right format? Burn as VCD (Video CD) or SVCD (Super Video) CD?
4. Since your files are in MPEG format, no encoding processes would be needed.
Now these are only the few things to consider. check it out I hope this could help. -
Yes it is the beter player I know.
I have one and period!...
OK!thats quiet easy to make your mpgs play in yourNintaus: -
1º- with tmpgenc transform your file in a mpg1 to VCD;
2º- burn the file Nero 5 or EasyCd 5 with option VCD
YOU MUST re-decode your mpg file to make a Video cd, and that task is in tmpgenc.
I really need som help here.
I have tried to use the TMPEGENC thing too, without success.
My NINTAUS will not accept the cdr when I am trying to watch the MPEG file..
I have usr tmpegenc first, then, burn it with NERO 5.5.5.1 on VCD option. 2x speed.
Please anyone, help !! -
I tried my cd-rw disc, and it worked!!
Why didn't it work with my NINTAUS and ordinary CDR discs ??
Anybody ??
It seems to be a problem playing ordinary VCD cd's that are recorded, but not cdrw discs... Anyone ??
I also have a Nintaus and I've never had any problems, cheap cdr or expensive... no probs.
It could be the media though.
The CDR brands that always works for me is:
Mr Platinum (80 mins)
Kodak CDR Ultima 80
Maxell 80 XL Pro (Something)
Also, try to use a cleaning CD (Isn't too expensive) to freshen up the Lenses inside your machine...
What does the machine tell you? No Disc or Disc Error?
Magnus Jensen
A.K.A Geezus -
My Nintaus say "No Disc" I have tried several cdr discs.
Is there maybe a way to reset my nintaus ?
Hmmm... Now I don't have a clue...
I thought that it was the medium...
It's probably a problem with the authoring, try VcdImagerEasy WITH CDRDAO.
Perhaps this could fix it.
I don't know of any way of resetting the Nintaus, try to Email them but don't expect a reply in technical issues...
Try to use a lens cleaner if you haven't already.
Another thing that's stated in the Manual is: Turn of the Power of the machine (Not on the Remote) and leave it off for a while... Then restart it...
I hope that this can help you...
(Perhaps your player is defect...)
Magnus Jensen
A.K.A Geezus
Getting two fatal errors when extracting mpgs from vobs
By Antony in forum SVCD2DVD & VOB2MPGReplies: 5Last Post: 15th Apr 2012, 01:24 -
Nintaus N699 DVD player
By hibuckles in forum Newbie / General discussionsReplies: 0Last Post: 12th Jan 2012, 21:10 -
Making mutilple MPGs from Avi Files
By funkymix in forum ffmpegX general discussionReplies: 2Last Post: 16th Mar 2009, 23:37 -
Join several mpgs together
By milway in forum Video ConversionReplies: 2Last Post: 13th Jul 2008, 21:49 -
Quick Question re: Joining mpgs
By boing in forum Newbie / General discussionsReplies: 10Last Post: 19th May 2007, 14:35
