Is there an easy way to create chapters with TMPGe? If there is, I'm apparently missing something....
Thanks-
you typically create chapters via the DVD Authoring tool you use, i.e. TMPEGDvD author, etc. not during the encoding step.
Exactly what he said.
TMPG DVD Author is Basic and really simple to use. There are other authoring programs that probably do more, but for noobs such as myself, I can't imagine an authoring program being any easier with the same features. I think they have it for D/L on the left.
pc crashes when using tmpge 4.0
By ANTS17 in forum Video ConversionReplies: 1Last Post: 11th Oct 2010, 23:55 -
GUI for dvdauthor - How to make chapter thumbnails run the chapter video
By deco81 in forum Authoring (DVD)Replies: 4Last Post: 15th Dec 2008, 12:51 -
.avs scripts in TMPGE Xpress?
By ecc in forum Video ConversionReplies: 0Last Post: 12th Aug 2008, 08:39 -
TMPGe and BD template the right settings for pal -getting juttering effect
By millzy in forum Authoring (Blu-ray)Replies: 0Last Post: 31st Jul 2008, 11:13
