using nero to burn menus on my VCD's works fine in my pioneer Dv525 but when I put it in my Apex 660 the menus dont show on the screen and only the first chapter plays and the next chapters follow suit after. Is this a authoring problem or a prob with my player.
I don't have an Apex, but do you have "PBC" turned on for your player?
Regards.
Michael Tam
w: Morsels of Evidence -
I have the same problem and the same conditions, which leads me to believe it is the Apex 660. I can still access each individual clip on the VCD, but the menu is nowhere to be found. I have tried with PCB on and off, with no difference.
Does anyone know of some software VCD players that will let me see if I am doing the menu right?!
I am using Nero 5.5 to burn and create the menus.
Does anyone have an Apex 660, and create their VCD's in another program AND get the menus to work?!
I remember vaguely someone mentioning that you have to press "PLAY" on the Apex to start PBC interpretation. Have you tried that?
Regards.
Michael Tam
Thanks, I ended up discovering that on accident. I thought I had to hit the root menu/digest button, but it was just a simple "PLAY" that did it.
Guide for extracting menus for editing, and reinserting edited menus
By manono in forum Authoring (DVD)Replies: 167Last Post: 8th Dec 2022, 03:44 -
Menus folders or sub-menus
By GymDad in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 9th Nov 2008, 08:43 -
Nero 8 DVD menus simulate fine but transcode errors on final dvd movie
By perfection in forum Authoring (DVD)Replies: 1Last Post: 1st Nov 2008, 04:01 -
Magix Movie Edit Pro Menus and Sub-menus
By gayclarke in forum Authoring (DVD)Replies: 8Last Post: 11th Aug 2007, 11:07 -
Authored DVD with GFD, fine on TV, no menus when playing on computer.
By towtruck in forum Authoring (DVD)Replies: 6Last Post: 8th Jun 2007, 18:40
