can someone tell me how to convert a vob file to mpeg2?
The surest way is to use Virtual Dub mod while frameserving to TMPGEnc. There seems to be an easier way of relabeling the file extensions to .mpg. but there seems to be a failure rate of about 20% I've heard.
Hello. -
bottle-necked: i tried your way but i got an error saying that there was a buffer underflow and the video might have problems.
Tommyknocker: i not sure what you meant by "use Virtual Dub mod while frameserving to TMPGEnc" ? -
I would then say you have a rip problem. Try ripping the vob again. If you ripped it as 1-large vob sometimes that can cause it. I've had that happen before.
At last resort just author the vob with TMPGEnc DVD Author, save to hdd folder, then demux that. Author can't encode video so the quality will be untouched. It will let you select the audio stream you want to keep and disregard the rest. This might correct the rip problem.(?)
Good luck. -
Try this guide, but use Virtual Dub mod instead of Virtual Dub.Originally Posted by qwerty99Hello.
Qwerty99. I am trying to do the same thing as you did. I have Tmpge, I will see if it works. Did you have problems with the advice they gave you?
Did it work/not work.
DVD to VOB/MPeg2
By Westport in forum MacReplies: 6Last Post: 9th Oct 2011, 20:41 -
VOB into one(!) mpeg2 file
By mitchellgoosen in forum ffmpegX general discussionReplies: 2Last Post: 13th May 2009, 09:19 -
DVD (VOB) files to mpeg2
By maxamillion in forum DVD RippingReplies: 7Last Post: 17th Dec 2008, 23:37 -
Vob / Mpeg2 editing with Vdub
By schematic2 in forum Newbie / General discussionsReplies: 4Last Post: 29th Jun 2008, 17:55 -
VOB to MPEG2(lossless)
By santosh86 in forum DVD RippingReplies: 1Last Post: 6th May 2007, 14:29
