Hi
i would like to know if there is a way to do a sampling of a conversion before doing a big one. Let's you have a 700 Mo Avi file DivX that you want to convert into a MPG2 SVCD file. Instead of waiting 6 hours to see that the result is bad. I would like to know if it is possible to try converting let's say a 1 or 2 minutes sample of the entire movies and see if the result work fine, if it is THEN i can try to convert the entire 700 Mo movie. I think this would save me A LOT of time.
Thanks for your help
Humm what a niceeeeeeeeeeee option
Thanks a lot
I have one question :
Is it normal that if i convert a little part of a movie with this option that i can't scroll in the movie when i watch it ? The scroll bar also stay at the beginning of the movie. (but the movie play properly) I use windows media player. -
I believe it depends on the codec being used. Some will allow scrolling in Media Player, others will not.
Hello. -
I tryed it in media player classic
and the scroll bar moved and i could scroll without any problem during the movie, so apparently it was an option not available in windows media player.
Thanks alot
Program like XenonMKV but with sampling rate conversion?
By shanghei in forum Video ConversionReplies: 1Last Post: 11th Nov 2011, 08:20 -
Understanding Video sampling rate
By Movie-Maker in forum Newbie / General discussionsReplies: 2Last Post: 25th Aug 2008, 17:07 -
4:2:0 - more than one type of Cb Cr sampling direction ?
By Movie-Maker in forum Newbie / General discussionsReplies: 3Last Post: 20th Aug 2008, 16:45 -
Issues with sampling/audio sampling/data rates and VdubMod
By Suprman37 in forum Video ConversionReplies: 4Last Post: 22nd Feb 2008, 01:09 -
how to rip audio from DVD and AVI without re-sampling
By ted demen in forum AudioReplies: 9Last Post: 23rd May 2007, 10:23
