I just bought an LG GSA-4081b and every program I use to burn only gives me the x2 option. This happens even without a disc loaded using drive/recorder info so I don't think it's just the media.
I'm running win98SE with an Gigabyte 7VAXP, Athlon 2100XP and 1GB ram.
Any info would be appreciated.
sounds like the same problem as with the 4040b.
make sure you're updated to the newest firmware.
but beware.. in the firmware is built in what discs are allowed to burn at what speed. the 4040b is only a 4x drive.. but only a certain amount of discs are authorized to burn at 4x. so alot of people can't burn 4x on cheap media.
when you use an LG drive you have to buy good media.. specific media.
try Ritek disks.
also remember the 4081 only burns 8x on dvd+r's.. so you gotta find some ritek 8x disks maybe -
I'll get some 8x discs and let you know. The discs I've been using have been the cheaper ones.
Laptop is showing nothing on screen.
By chewie8008 in forum ComputerReplies: 4Last Post: 26th Jun 2011, 22:56 -
Video not showing
By Clem Porterhouse in forum DVD RippingReplies: 4Last Post: 31st Mar 2011, 04:06 -
Subtitles not showing
By marukomu in forum SubtitleReplies: 17Last Post: 16th Nov 2009, 20:39 -
New signature not showing on all forums?
By Midzuki in forum FeedbackReplies: 6Last Post: 16th Jul 2008, 11:53 -
Plugins not showing up in VirtualDubMod
By Matsuemon in forum SubtitleReplies: 8Last Post: 12th Mar 2008, 05:18
