how can i convert a divx.avi file with subtitles into a svcd i tried everything divx to svcd is no problem but adding the subtitles is confusing if someone can help me out thanks !
Results 1 to 11 of 11
What form are you subtitles in, and what have you tried exactly.
Hello. -
im having the same problem.....i have an AVI file with subtitles that im trying to convert to SVCD, and i have no idea how to extract the subs. the subs are part of the avi file (not included as a separate file), and i know they aren't hardcoded because i can turn them on and off in media player. when the file is played in media player, the subs play fine, but when i use tmpgenc to save .m2v file, the subs don't carry over.
any help with this is most appreciated!! -
also, i tried opening the file in virtualdubmod and demuxing the subtitles stream, but the audio track is the only track that shows up when i go to the stream list
I've never seen an avi with selectable subs.
I've seen ogm files and mkv files with selectable subs, but never seen an avi file with selectable subs.
there may be a sub file in the same directory that your system is automatically loading when playing the avi file.
I would do a search on your hd for *.srt, or *.sub or *.idx and see if it comes up with any results.
how many streams does it show in virtualdub?
pm me where you got the file.
you've totally peaked my curiosity. -
Isn't it possible that the subs have been hard encoded into the avi?
must be it, ........Originally Posted by teegee420
i hate it, when i get one of those, and the subs are in german
g_i_l_s_t_e_r
Just the product of a society that's lost it's good manneres -
The VobSub suite includes a utility called SubMux, which allows you to multiplex a subtitle stream into an AVI file. The file maintains its .AVI extension, but the subtitles are switchable via DirectVobSub. I just did a quick test with some files I had lying around, and found that subtitles muxed this way are not recognized as a separate stream by VirtualDubMod, and thus cannot be extracted that way.
I was able to recover the subtitle file by opening the full AVI in a hex editor (I use Hex Workshop), searching for a couple words from the subs, selecting the SSA script, and saving the selection as an SSA file. This extracted file has the same CRC as the original SSA file I used.
You should be able to get your subtitles this way. If anyone's come up with a better way to extract them, I for one would be interested in hearing it. -
Hmm, good info morford. I didn't know that was possible.Originally Posted by Morford
How to add permanent subtitles with AutoGK and convert to AVI DivX or XviD
By Baldrick in forum SubtitleReplies: 263Last Post: 17th Jun 2018, 16:18 -
Dual or Multi Audio AVI with subtitles (MPEG4 XviD DivX)
By DereX888 in forum User guidesReplies: 16Last Post: 20th Dec 2012, 16:24 -
ffmpegX - idx/sub subtitles lost in converting from avi to Xvid or DivX
By bonespur in forum MacReplies: 5Last Post: 4th Mar 2011, 03:25 -
Creating my own subtitles and adding them to an AVI (divx) file? Best way?
By Chrushev in forum Newbie / General discussionsReplies: 1Last Post: 9th Jan 2010, 05:12 -
adding subtitles to AVI (xvid or divx) WITHOUT re-compressing
By truthlesshero in forum SubtitleReplies: 2Last Post: 22nd Dec 2009, 11:43
