I'm just wondering, planning to buy a Sony DV-nc665p.w/ progressive scan...will it destroy my tv if i use the progressibve scan feature? Thanks for any reply...
Results 1 to 18 of 18
There is no way you can enjoy the progressive scan feature un less your tv is hdtv ready with component video in (RED/GREEN/BLUE) rca inputs because your tv needs to be able to display 480p (progressive) which is like a line doubler.If your tv is an anolog tv the best you can get is 480i which is an interlaced connection which in case even if your tv has component video in and you set your dvd player to progressive all you will get is a screen full of static. And finally the only way to get progressive is by component 480p inputs and thats all because s-video cannot give you a progressive scan picture,I hope this helps. P.s. sell your old tv and get an hdtv they start at $800.00 bucks and up.
It will render your T.V. useless, and will force you to buy a new HDTV ...
Just kidding
Well part of it's true. You'll only truly get to enjoy the progressive scan on either your computer monitor, or an HDTV, since they both support progressive scan..
Good luck!! -
Hello, I just bought a Sony DVP NC-875V DVD Player with progressive scan and connected to my old VPL CS10 Sony projector via the component video cable. The problem is that I can't see anything. Not only from this DVD but neither with the old DVD player that hasn't progressive scan. Can anybody give me some orientation??!!
you prob have it switched to RGB . not component
Correct me if I'm wrong, but I always thought that you don't need HDTV to enjoy progressive scan.
All that is necessary is a component connection. If you have components on your TV, than hook up a progressive scan dvd player via component and you will get progressive -
See this thread for the issues.
https://www.videohelp.com/forum/viewtopic.php?t=244182 -
Originally Posted by ancient4
What I mean is that any TV can display 480p, right?
480i is standard, plug in a progressive DVD player with component, and you get 480p. -
projectors can take interlaced input -- any projector ..
tv may not display 480p , some can .. but not just run of the mill tv will play 480p"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
I'm running my progressive scan dvd player into my new Phillips HDTV Monitor (PHL 27PT8302) via S-Video. Does S-Video allow for progressive scan? Or should I use the component output? Thanks!
Ok, learn something new everyday.
So there is no advantage to getting a progressive scan DVD if you have a standard Tv (even though I do have an HDTV) -
you might as well get one though so it will serve you down the road.
and since they are now the same price basicly anyway
Will a progressive scan MPEG2 work on all DVD Players?
By jnms in forum Authoring (DVD)Replies: 29Last Post: 30th Oct 2011, 16:22 -
BD/DVD Interlace vs Progressive Scan: Which is better?
By Bonie81 in forum Newbie / General discussionsReplies: 9Last Post: 2nd Dec 2010, 06:01 -
Are there progressive scan DVD discs??
By seekt in forum DVD RippingReplies: 33Last Post: 21st Oct 2009, 12:52 -
Do laptop dvd drives play in progressive scan?
By ieh4f in forum Newbie / General discussionsReplies: 8Last Post: 29th May 2008, 19:36 -
Creating DVD for progressive scan DVDplayer/TV
By halsboss in forum Authoring (DVD)Replies: 1Last Post: 18th May 2007, 19:58
