C:\Documents and Settings\username\Local Settings\Temporary Internet Files\Content.IE5 directory?
i've tried deleting all the files in this folder, but it wont let me delete the index.dat folder & a few other folders.
whats the use of this folder and why cant i delete all the files/folders in this folder?
thanks for any help anyone can provide.
it's where your IE temp files go. index.dat indexes the files.
You should be able to delete everything but that folder and the index file. all subfolders (hidden in most cases) can also be deleted -
goto a Dos Box and type "Format C: /x". This will get rid of those pesky folders
stiltman,Originally Posted by stiltman
maybe some of the temp net files go there, but the majority of them reside in the;
i've got hidden folder viewing on, but it still wont display the Content.IE5 folder within it.
what gives?
Whats the best way to capture pictures?
By chrisy76 in forum Newbie / General discussionsReplies: 4Last Post: 23rd Jul 2010, 18:56 -
Whats the best audio codecs to have
By adamf154 in forum AudioReplies: 4Last Post: 7th Apr 2010, 18:31 -
whats authoring?
By templedog in forum Newbie / General discussionsReplies: 3Last Post: 17th Nov 2008, 01:28 -
Whats in the pipeline?
By 2Tents in forum SVCD2DVD & VOB2MPGReplies: 12Last Post: 7th Jul 2008, 12:39 -
Whats the best way to get just the audio from a mini-dv?
By Jensen in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 25th Dec 2007, 20:06
