    Apr 2003
    Are all firewire, ieee 1394, and i.link cables compatible with all firewire, ieee 1394, and i.link cards?
    I want to connect a digital camcorder to my PC through a firewire cable, but my PC doesn't have a firewire input port. To make sure that I buy the right cable & the right card, I wanted to ask if these are all compatible with each other? Thank You!
  2. IEEE 1394 si the Technical anme and firewire is a common name used and i.link is the name given by sony for this Type of Posts. they are all one and the same and any fire wire cable will work
    Baskaran Swamiappan
    Englewood,CO
    baskis@gmail.com
    Apr 2003
    Thanks, sumibas -
    I guess I just don't speak the right language yet. Where does the firewire input port come from? Is it part of the card? I've obviously never taken my computer apart & I just don't understand how I get a firewire input port in my computer, so I can connect the cable. Thank You!
    Apr 2002
    The State of Frustration
    You buy a fire wire card. The card plugs into your PCI slot, and has built in ports.
    Hello.
    Apr 2003
    Makes sense now ... thanks, Tommyknocker!
