Hi, an am trying to create a DVD compliant files ready for burning from a *.mpg when I load the file into TMPGnc author I get an error.
How do I adjust the GOP length?the video GOP is too long
Thnaks!
Couple options.
1) Reencode the video file using a proper dvd template to start. Max gop is 18 for ntsc and 15 for pal I believe.
2) The only other way is use a different auth program that will let you ignore the error and hope your player will play the files.
I vote for option one personally. -
1) hit ignore and author anyway. it will play
2) use womble mpeg-vcr. under the tools menu check gop fixer. -
Thanks for your ideas.
I got installed a copy of Womble and it fixed the GOP issue, only to replace it with another problem. This time I am getting this error message.
And I get this when as soon as I try to load up the file in Author.Could no initalize decoder
Ideas??
incorrect GOP when trying to author DVD with files extracted from VCD
By ibzomie in forum Video ConversionReplies: 2Last Post: 20th Jan 2012, 10:58 -
How to play pics adjusted on a PC to a TV ?
By DBenz in forum Software PlayingReplies: 3Last Post: 3rd Jun 2011, 01:38 -
Opening a video in Sony Vegas 7.0 with auto adjusted aspect ratio?
By ilimitus in forum EditingReplies: 1Last Post: 6th Feb 2011, 22:52 -
New_Face failed. Maybe the font path is wrong plus Adjusted n subtitle(s)
By etruscan in forum ffmpegX general discussionReplies: 3Last Post: 4th May 2008, 01:50 -
SCR <> GOP error in Gui for DVD Author
By rain in forum Authoring (DVD)Replies: 6Last Post: 22nd May 2007, 12:51
