  1. I have downloaded the 205e.exe file to flash my firmware but when I try and copy this onto my bootable disk it just says that the destination file is full. What am I doing wrong. Do I need a smaller MS-DOS bootable disk and if so how do I get this.
    Cheers
  2. Sorry I should have said I am running window XP Home
  3. I have found Drdos and got it all on one floppy. I still can't get the thing to work.
    At the dos prompt :\> to I just type in UPDATE 205e.bin I keep doing that and I get no joy.
    Any ideas what I am doing wrong?
  4. Member ViRaL1's Avatar
    Jan 2004
    Making the Rounds
    If you got the file from Optorite's support / firmware page, it's a Windows executable. You shouldn't need a bootable floppy to run it, if you're downloading it on a machine other than the one with the 201, just copy the .exe from the floppy to your desktop and run it from there.
    Nothing can stop me now, 'cause I don't care anymore.
