Hi,
I have a few questions on the various formats:
How can I tell if a .mpeg file is a VCD or SVCD.
How can I tell if a .avi file is DIVX, XVID, or AVI ?
If I convert DIVX to DVD format, is the quality compromised?
Thanks,
Derrill
https://www.videohelp.com/play#identify
if mpeg1 and 352x240/288 it is VCD and if mpeg2 480x480/576 it is SVCD. -
Use GSpot to determine what codec you are using to decode an AVI. There's numerous versions of DivX and XviD, but all are MPEG4 codecs and can be interpreted by your computer multiple ways (The #1 reason XviD has green blocks isn't the encoding, it's the decoding).
As to MPEG, drop it into a player and look at the resoltuion. Most players like PowerDVD will give you a resoltuion and type (MPEG1 or MPEG2). Framerate is important for movies you downloaded, since trying to convert a 25 fps PAL movie to NTSC is a pain.
For any video, framerate and resolution is important (PAL/NTSC issues). Interlacing is also important, since certain DivX support it, but it's very uncom,mon.....while MPEG2 is generally always interlaced (except the lowest resolutions).To Be, Or, Not To Be, That, Is The Gazorgan Plan
My DivX DVD Player can't play my avi DivX/xvid video
By Baldrick in forum DVD & Blu-ray PlayersReplies: 32Last Post: 6th Mar 2015, 09:11 -
Best MKV to Avi=divx/xvid
By s-toon in forum Video ConversionReplies: 9Last Post: 9th Aug 2011, 15:50 -
players that play all formats (avi, divx etc)
By ps1on in forum DVD & Blu-ray PlayersReplies: 1Last Post: 28th May 2010, 12:14 -
DVD to AVI (done) to Divx or xvid
By Grumpy_one in forum DVD RippingReplies: 3Last Post: 16th Mar 2009, 17:28 -
best avi (divx/xvid) to cd-r (vcd) converter
By waefwaeefwaefw in forum Newbie / General discussionsReplies: 8Last Post: 15th Sep 2008, 12:36
