  1. i tried to update my firmware but it froze and when i re booted pc it doent recognize my dvd rom or writer
    what can i do to fix it?
  2. have i done the unthinkable and knackered my dvd writer when i was using the firmware?
    when i disconnect dvd writer the pc recognizes my dvd rom.
    when i connect only dvd writer and put little switch to master it's as dead as a dodo.
    is there anyway to get writer working again?
  3. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    Could it just be that you have both drives set to master ?
    If in doubt, Google it.
  4. its not the switches. problem only happened after i used firmware
    have been on pc help rooms and other forums im pretty sure i've murdered my dvd writer
  5. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    Still under warranty ?
