I've looked into several options, but DishNetwork will swap out one of my receivers for $100 installation fee and no extra charge a month, which is a lot cheaper than I could ever get even a non-HDD DVD recorder for. The latest model will hold up to 100 hrs., so that's way more than I'd ever need. I have one downstairs that holds 25 hrs. and I've never filled that one up.
Occasionally I transfer something to VHS, but if I had one in my room I wouldn't need to do that. I'd swap the downstairs one for mine upstairs, but the plain receiver doesn't have an optical digital audio output, so I'll just get the newer HDD one.
It will be a while before I get a DVD recorder with the HDD, since most are at least $500. Maybe if the DishNetwork deal changes, I'll look into it....
Results 31 to 32 of 32
Understanding the nature of legitmate backup for own personal use,
I have succesfully backed up macro-ed vhs using a mitsubishi dvhs vcr (w/tbc) through a Video Enhancer from FacetVideo to my sharp DVD Recorder.
The TBC does a great job of cleaning up the video but isn't necessary as well as using s-vid connections but what is essential is the Video Enhancer and at $99.00 it is sweet.
A cleaner solution would be to capture at high bitrate on a computer but using this configuration is near realtime with only menus being added using DVD Author after transfer from dvd-rw to computer and then burn using RecordNow.
whats the best printable discs to use for a govideo dvd vcr combo
By zerocoool in forum MediaReplies: 1Last Post: 7th Mar 2010, 23:13 -
DVD Recorder/VCR With No Tuner - Link to Broken Tunered DVD Recorder
By Surfmaster in forum DVD & Blu-ray RecordersReplies: 1Last Post: 23rd Dec 2008, 02:05 -
Costco is Selling New Toshiba DVD Recorder w/DIVX for $130
By peggypwr1 in forum DVD & Blu-ray RecordersReplies: 43Last Post: 5th Feb 2008, 02:13 -
GoVideo DVD/VCR
By candela in forum DVD & Blu-ray RecordersReplies: 2Last Post: 10th Dec 2007, 09:05 -
tv/vcr to dvd recorder
By jjis in forum DVD & Blu-ray RecordersReplies: 2Last Post: 8th Oct 2007, 15:35
