  1. leethomson
    Guest
    I have a 2 GB multiplexed MPEG-1/2 file that I am trying to demux which is starting to concern me. The progress bar on this baby hit 99% after ten minutes and has held steady now for twenty-six hours. What started off as a single 2 gig file is now a 300 meg mp2 audio file and an EIGHT GIG MPEG-1 video file which gives no indication of ever halting its annex of my hard drive.
    Is this normal, really? I'm using an 867 G4 and only running about three other mild applications.
  2. It is totally anormal to demux to a size larger than the source. Stop the process and try to use "Split in 1 chunks" on the source mpg file to see if it helps doctoring it.
  3. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    There is no "program end code" on the original mpeg and so some demuxers just don't stop! They will fill your HD.
    Try another demuxer.
