I have converted some DivX and Xvid encoded video to MPEG2 for DVD and I have found that I am loosing some subtle audio quality.
My source files have 160kbs encoded stereo audio which sounds very good and crisp.
I use TMPEGenc with tooLame audio plugin. I mimiced the audio settings of the source - i.e. 160kbs audio. My thinking here was that the source was 160kbs so a higher bitrate would not help me out. What I do not know is if I am not comparing apples to apples. I.E. in my source, the audio is probably mp3, is this true for the MPEGII DVD format audio?
Is this the first point I went wrong? Should I have accepted the default from the DVD template for the Audio bit rate?
Obviously I have some work to do on my end to experiment with this- I am wondering if I
a. use VirtualDub to strip out the audio, then just encode the video, then feed TMPEGDVDAuthor the VIdeo and Audio separately, would that maintain the quality?
or
b. if I encode the audio/video at once (with tooLame setup) at a higher bitrate?
Just curious what the best way to keep 100% of the source audio quality is.
Thanks, Chops1400
Results 1 to 1 of 1
Rip DVD to Divx/Xvid with AC3 Audio
By dudeman316 in forum DVD RippingReplies: 6Last Post: 3rd May 2009, 04:25 -
Philips DCP850 DivX overall quality (and DivX subtitle handling) question!
By mabhz in forum DVD & Blu-ray PlayersReplies: 0Last Post: 3rd Jul 2008, 19:59 -
Convert .h264 to divx/xvid or dvd success with slightly lower quality.
By Edgelessdiamond in forum Video ConversionReplies: 13Last Post: 26th Apr 2008, 22:21 -
Best (easiest) DVD to (DIVX or Xvid) with 5.1 (AC3) Audio out
By balagan in forum DVD RippingReplies: 5Last Post: 11th Dec 2007, 16:16 -
Audio Problems with divx,xvid etc on dvd player
By iain123 in forum AudioReplies: 6Last Post: 30th Jun 2007, 15:57
