  1. i know how to extract cue files into mpeg but i have a bin file as of right now without a cue file and i was wondering how i would go about turning the bin file into mpeg?
    i use vcdgear to turn cue into mpeg but it wont do that with a bin file, any suggestions?
  2. Member rhegedus's Avatar
    on the jazz
    Try mounting the image as on a virtual drive using DaemonTools.
    Regards,
    Rob
  3. Or rip it apart with ISOBuster.
    Cheers, Jim
    My DVDLab Guides
  4. You can make .cue files you know, just open up one of the ones you have and just change the file name in the text file itself, then save as whateveryouwanttonameit.cue. That works for me when I am missing a .cue file.
  5. Member jaxxboss's Avatar
    Apr 2003
    JAX, FL
    If you just want to watch it, use the first answer, if u wanna burn it use the 2nd and if u wanna burn it as a bin/cue use the 3rd.
