Hi,
I started using DVD shrink in combination with a NEC ND 1300 DVD +/- writer on ME OS.
Shrinking is finished normally, files are copied to HD in the audio and video folder. So far so good.
I use Nero 6 to burn DVD's (Philips DVDr or Princo DVDr) on 2 speed.
Burning finished ok.
On my KISS DP450 player (+/- player) the image is very bad and finally freezes.
What am I doing wrong, already wasted some discs. Thanks a lot !
Quite possibly nothing, other than using bad media.
Try a different brand/type of media. Check the media forum for suggestions. -
I would say bad media as well and don'g ignore how utterly bad Win ME is. I'm on an XP Home machine 2.4 p4 with only like 512 RAM. and latest version of nero 6. I am ripping and shrinking with dvdshrink 3.1.5 Beta and it works perfect even with crap Princo 1x I normally use Ritek G04 which can be had for about $1 in 100 spindles. Search for internet media resellers.
No DVD can withstand the power of DVDShrink along with AnyDVD! -
Usually it's crap media. Secondly it's a crap player. How does it look on your PC? Friends player?
To Be, Or, Not To Be, That, Is The Gazorgan Plan
Newbie Help Needed for making Videos
By stroke in forum Newbie / General discussionsReplies: 8Last Post: 6th Mar 2011, 07:42 -
[ HELP NEEDED ] BD-ROM to BD-R 25 with BDRebuilder: how much CPU is needed?
By Tyrexionibus in forum Blu-ray RippingReplies: 1Last Post: 28th Oct 2009, 12:27 -
You want newbie? This is newbie. Watch VHS movies.
By Mighty Melvin in forum Newbie / General discussionsReplies: 14Last Post: 12th Oct 2009, 08:43 -
Authored DVD exceeds DVD spec bitrate - advice needed.
By outerspacerace in forum Authoring (DVD)Replies: 27Last Post: 14th Jun 2008, 22:23 -
Memory upgrade needed for TMPGENC DVD Author 3, advice needed
By Caned_and_Able in forum ComputerReplies: 8Last Post: 31st Jul 2007, 18:30
