I just placed two small features to a DVD+RW....the first one is NTSC and the second one is PAL. Will this thing play on a normal DVD player? It plays fine on my computer DVD player...however I don't think I can really test it correctly on a stand alone DVD player because my stand alone is capable of playing BOTH NTSC and PAL. Think it will work?
Depends who your making the disc for !
If for yourself then yes it should work but for others that all depends weather thier players can play both NTSC+PAL
I've done quite a few mixed discs myself and most UK playes I've come accross can play both formats. -
So I guess that means this will NOT fool an American DVD player into thinking the second piece is also NTSC?
Pls help! Best way to convert NTSC VHS (captured using PAL VCR) to NTSC DVD
By rairjordan in forum Capturing and VCRReplies: 33Last Post: 28th Nov 2013, 11:33 -
when Pal dvd has correct Ntsc audio (Pal>Ntsc conver)
By spiritgumm in forum Video ConversionReplies: 15Last Post: 13th Oct 2011, 12:57 -
DVD players that play PAL & NTSC - do you need a PAL television?
By ibzomie in forum Newbie / General discussionsReplies: 9Last Post: 12th Dec 2010, 20:53 -
Creating NTSC Blu ray DVD From PAL TS Files. need help with NTSC format
By Rick0725 in forum Authoring (Blu-ray)Replies: 0Last Post: 9th Apr 2009, 21:43 -
PAL VCD -> NTSC Video for NTSC DVD Authoring!!
By Mickey79 in forum Video ConversionReplies: 5Last Post: 12th Aug 2008, 11:30
