Hi,
I started using DVD shrink in combination with a NEC ND 1300 DVD +/- writer on ME OS.
Shrinking is finished normally, files are copied to HD in the audio and video folder. So far so good.
I use Nero 6 to burn DVD's (Philips DVDr or Princo DVDr) on 2 speed.
Burning finished ok.
On my KISS DP450 player (+/- player) the image is very bad and finally freezes.
What am I doing wrong, already wasted some discs. Thanks a lot !
Newbie Help Needed for making Videos
By stroke in forum Newbie / General discussionsReplies: 8Last Post: 6th Mar 2011, 08:42 -
[ HELP NEEDED ] BD-ROM to BD-R 25 with BDRebuilder: how much CPU is needed?
By Tyrexionibus in forum Blu-ray RippingReplies: 1Last Post: 28th Oct 2009, 13:27 -
You want newbie? This is newbie. Watch VHS movies.
By Mighty Melvin in forum Newbie / General discussionsReplies: 14Last Post: 12th Oct 2009, 09:43 -
Authored DVD exceeds DVD spec bitrate - advice needed.
By outerspacerace in forum Authoring (DVD)Replies: 27Last Post: 14th Jun 2008, 23:23 -
Memory upgrade needed for TMPGENC DVD Author 3, advice needed
By Caned_and_Able in forum ComputerReplies: 8Last Post: 31st Jul 2007, 19:30
