The ones I captured with the PVR-250 card and the Instant DVD device are OK but the ones captured via Firewire/MPEG-2 software encoding in Ulead DVD MovieFactory are reported as being "Illegal" and crash the program. The weird thing is that I've successfully authored DVDs using files captured via Ulead DVD MF. Any ideas?
Did you verify that it is creating valid DVD files, and that the resolutions and audio are OK (like at 720x480 or 352x240 mpeg-2, with 48 Khz audio, etc)?
Yep. All the settings are correct and the resulting file is fine and can be used to make DVDs. Just wondering why PVA says they're illegal.Originally Posted by Forum Troll
Is it a System Stream or Program?
To Be, Or, Not To Be, That, Is The Gazorgan Plan -
Program, I believe, but I'll double check when I get home.Originally Posted by Gazorgan
Update: The problem is with files created with LPCM audio only. Files created with MP3 audio (384Kbps) can be read just fine.
Still wondering why though.
Free software to split large MPEG-PS file into many small MPEG-PS files?
By videonewbie22 in forum Newbie / General discussionsReplies: 9Last Post: 5th Jul 2018, 20:16 -
Choppy playback of some MPEG-2 files and all IFO files
By ANOther1676 in forum Software PlayingReplies: 2Last Post: 8th May 2011, 07:04 -
Convert .mpeg-files to .vob-files?
By stuckinsnow in forum Authoring (DVD)Replies: 1Last Post: 21st Sep 2008, 05:06 -
No audio in powerdvd for mpeg 1 and mpeg 2 files
By Bully9 in forum AudioReplies: 2Last Post: 2nd Jan 2008, 08:23 -
DATA files rather than MPEG files from a DVD-Video?
By DieselsDen in forum Newbie / General discussionsReplies: 11Last Post: 14th Dec 2007, 04:24
