I have captured video as svcd format , now i am trying to extract only audio in wav or mp3 format from my video files, is there anyway i can do it ? thank you
In my opinion the easiest way to do this would be to open your SVCD mpeg with Virtualdub MPEG2, go to the audio menu and select "Full Processing Mode", then go to the file menu and select "Save WAV". This will create a PCM wav file.
If you want to create an mp3 file instead, make sure you select mp3 and the applicable bitrate by selecting "Compression" in the audio menu prior to saving as wav. When selecting a file name, move the "Save As Type" slider to "All Files" and make sure your file name ends with the ".mp3" extension instead of ".wav". -
Ditto.Originally Posted by teegee420
Willtgpo, my real dad, told me to make a maximum of 5,806 posts on vcdhelp.com in one lifetime. So I have. -
Thank you teegee420 very much it worked great.
Originally Posted by teegee420 -
Virtual Dub works well most of the time, but I have found some commercial VCD from abroad the audio extraction is not always complete.
If you are fortunate enough to own Adobe Premier, you can separate audio and video tracks and then export the audio from there flawlessly.
Extract audio from MP4
By aiyoyo in forum Video ConversionReplies: 5Last Post: 12th Dec 2013, 16:35 -
how to extract audio from avi
By ShrinkDWorld in forum AudioReplies: 2Last Post: 2nd Feb 2012, 18:58 -
Extract Audio off a game CD
By ranchhand in forum AudioReplies: 9Last Post: 30th Mar 2011, 10:22 -
HOW do I extract 1 audio track from a .ts / .m2ts with 4 audio tracks?!
By elgy in forum DVB / IPTVReplies: 25Last Post: 24th Jan 2011, 00:28 -
How to extract audio from a MKV?
By takearushfan in forum AudioReplies: 3Last Post: 24th Jul 2010, 00:51
