Does anyone have a solution to this problem?
Using ATI AIW 128pro or Ulead5 with firewire in I can capture with no problems in MPEG 1 mode. When I try to capture (TV or VideoCam) in MP2, the sound is very distorted during playback with any player. I get the same distortion when playing DVD's with ATI's player or PowerDVD.
Lots of crackling (like playing an old vinyl record, especially at louder passages). I think the sensitivity is way too high, causing saturation. On PowerDVD I can change audio to Direct Sound instead of Wave out, which helps a lot when playing DVD's but not on own captures. I didn't find a Direct Sound option in ATI's settings. Adjusting volume on the Wave channel or main does not change the symptoms.
I'm using a P-III at 650 MHz and the sound built in on my Intel MB (Yamaha legacy sound).
Results 1 to 1 of 1
Capture card for 360.. Capture in SD play on TV in HD?
By fazeshot in forum Video Streaming DownloadingReplies: 4Last Post: 12th Nov 2009, 16:04 -
Capture and play AC3?
By lccomp in forum AudioReplies: 3Last Post: 13th Sep 2009, 10:56 -
how 2 play ps3 hd on tv and capture 2 my pc not hd
By wgpblade in forum Video Streaming DownloadingReplies: 0Last Post: 21st Feb 2009, 11:22 -
capture and play at any position
By mcc in forum ProgrammingReplies: 0Last Post: 12th Jan 2009, 03:17 -
Anyway to capture 720x480 using the Gamebridge and still play?
By Mysteriouskk in forum Capturing and VCRReplies: 0Last Post: 19th May 2007, 13:07
